TwinTurbo.NET: Nissan 300ZX forum - Check the celectrical connections at
DAYTONAZ
on September 23, 2008 at 6:06 PM
Still with the erratic idle. Desperate! Want to give up!
posted by rojoloco (San Diego)
on September 23, 2008 at 05:29 PM
the air regulator which controls cold start air bleed, and the IACV solenoids. Make sure the connections are corrosion free and also may want to remove and clean test the assemblies. Search the FAQ section.
17:29:53 09/23/08
Check the celectrical connections at -
DAYTONAZ
18:06:05 09/23/08
my bets on vac/boost leak
Bountywolf
18:27:47 09/23/08
Wouldn't that be a constant thing though?
18:52:10 09/23/08
Smaller vac. leaks will cause odd idle but as the car gets
03:03:19 09/24/08
Re: Still with the erratic idle. Desperate! Want to give up!
elcid
21:33:29 09/23/08
Had the same problem
nismo_boost31
23:51:55 09/23/08
"hunting idle" - do you have a service manual
spicyZ
20:09:54 09/25/08
